Re: pressure relief drain?
Posted by Deb on April 27, 2003 at 15:06:13:
In response to Re: pressure relief drain?
: We have a finished basement with a well pressure tank and a hot water tank. Both tanks have the required "relief" valves. My question is, can they be drained directly into the 3" waste line to the septic tank? The way they are terminated now (12" above floor) if they ever "BLEW" there would be a lot of water going all over the floor,even with a floor drain close by.Could we just pipe these to the drain line, and eliminate any flooding concerns? thanks for any reply. Don No. No line that is carrying discharge under pressure can be directly connected to any part of the drainage system. Deb The Pipewench
Replies to this post
There are none. |
