| Posted by Bruce Keats on April 27, 2003 at 15:04:33: | |
| In response to Re: Best pipe for trap primer to floor drain? | |
: IF you are using PVC or ABS drain piping then there is an adapter that fits between the drain and the trap that has the TP opening in it. The copper is sleeved plastic or tape. Thanks for the help. Is the adapter abs? The other option I am toying with is to order a complete abs floor. plumbest.com sells a complete unit that comes with the trap, cleanout and tp ports for about US $20. Bruce |
| There are none. |
