Re: new release vavle but water heater whistling
Posted by LonnythePlumber on April 26, 2003 at 18:26:27:
In response to Re: new release vavle but water heater whistling
: I replaced the pressuerw release valve but now the water heater is whistling loudly and is again spewing hot water outside... Help!! : Melanie Do you have an electric water heater? I presumed gas. I agree a burned out element would not cause over heating and that a faulty thermostat could. Do you have heat traps on your heater? They are coated nipples about 3" long on the inlet and outlet of your heater. They can cause the pressure expansion from heated water to set off the relief valve because the heat has no room to expand. LonnythePlumber
Replies to this post
There are none. |
