Pop-up assembly leaks
Posted by John Dernar on April 25, 2003 at 12:54:10:
I recently installed a new Crane china bathroom sink and an AquaSource faucet/pop-up assembly (all plastic)according to directions. Drain water is leaking from under the sink where the pop-up gasket is compressed against the bottom of the sink. The hole in the sink isn't perfectly round and the pop-up is a flimsy plastic device. Additional tightening of the pop-up nut makes the leak worse. The directions recommend not to use plumber's puddy at the top sink bowl opening. Any suggestions would be appreciated.
Replies to this post
