| Posted by bill on April 24, 2003 at 08:00:11: | |
| In response to Re: Go to ebay and buy a Ridgid Soil Pipe Cutter | |
: The trap arm length depends on the size of the pipe. I think 2" can be up to 8 feet, but check you code book. Better yet, find out who you plumbing inspector is and pay him a visit. These : guys are paid by your tax dollars and should answer your questions. From the sounds of it, your just dropping down through the floor and : want to connect into your stack. You should see if you can connect into your original vent, if you have one.
: : : If I read you correctly, you are planning to install an illegal and unsafe drain without a proper vent. : : : : Chuck, there is a fitting but it is on the first floor and there is a horizontal run of drain pipe along the wall. Previously they notched out the backs of the cabinets for this pipe...but the new cabinets I will not be able to do that. So I am rerouting it straight down through the floor into the basement, and then horizontally along the basement ceiling over to the stack : : : : : If this is a remodeling job isn't there a fitting
| There are none. |
