| Posted by LonnythePlumber on April 23, 2003 at 23:10:25: | |
| In response to Re: No hot water flow in shower | |
: In one of our showers the cold water flows normally, but there have been delays between hot-water valve turn-on and water flow for some days, until the hot water stopped flowing altogether. : When the hot-water valve is turned on, no gurgling or a sound of any kind is heard. : Only this shower is affected. All other water outlets in the house operate normally. : What could be the cause for the hot-water stoppage? If you have a two handle faucet it is probably debris. You can shut the hot water off at the water heater, remove the hot stem, and turn on the hot water briefly a few times. This may clear your debris. Do you have steel piping? If you have |
