plumbing under concrete slab?
Posted by Joe on April 23, 2003 at 09:39:14:
I'm in the process of turning a garage into living space, and need to get drain and supply lines to a new bathroom. The floor is poured concrete. I'm planning to rent a concrete cutter and jackhammer to open the trench, but am uncertain about what to do thereafter. Is it permissible/advisable to simply lay the pipes in the trench and pour new concrete over them? Would it be preferable to avoid copper for the supply lines and use cpvc instead? OR should I maybe just cover the pipes with sand before pouring the concrete? Thanks. Joe
