| Posted by Deb on April 22, 2003 at 19:24:54: | |
| In response to Re: water pressure | |
: i have a deep well that had all new parts replaced a couple of months ago. last couple of days when you flush the toilet or use the washing machine the plumbing in the house starts to shake and the pressure isn't that good. i checked the well and pump and its working ok. the outside faucet works fine too. a friend advised me that i might have air in the waterline somewhere in the house. can you advise anything else? There are alot of things that it could be. The interworking relationship between pump, pressure switch, and pressure tank need to be in harmony. There are check valves that could be sticking, washers that could be sticking. You could have a problem with the pressure tank, etc, etc. You might want to call the plumber who did the previous work, since he (or she :-) would be familiar with your system.
| There are none. |
