Re: Dishwasher Leak (new machine)
Posted by John B on April 22, 2003 at 14:47:41:
In response to Re: Dishwasher Leak (new machine)
I have a 4-1/2yr old Maytag that is leaking as well. After removing the inside door panel, I discovered a sponge gasket at the base that was completely soaked. It's obvious that Maytag new there would be some degree of leaking but there method of preventing drips is a poor design. I actually had wire insulation crack causing the unit to trip the circuit breaker. I had Maytag service fix the wire harness but they didn't fix the root of the problem. I will be replacing the gasket on my own. It looks like you at least have the opportunity to have this covered under warranty.
Replies to this post
There are none. |
