Re: How do toilets work?
Posted by Gary Swart on April 21, 2003 at 20:19:37:
In response to Re: How do toilets work?
That may very well be the problem. There could also be something in the toilet that is partly blocking the drain, but do the easy stuff first. Make sure the small tube inside the tank is clipped to the overflow tube so that it is squirting water into the tube while the tank fills. To clear the toilet's drain, you will need to remove the toilet from the flange and push a snake from the underside. This is not as difficult as you may think, but if you need advise on how to do it, email me or post a note.
Replies to this post
There are none.
