| Posted by LonnythePlumber on April 18, 2003 at 22:00:53: | |
| In response to Re: Rattling Pipes | |
: : My pipes rattle like thunder when no one is using any water. The noise comes once to four times a day and lasts about 30 seconds to a minute. Turning a tap on will stop the noise immediately. : : We've lived in the house for 6 months, and have only had the problem for about a month. We had an Aprilaire humidifier installed on our furnace around the same time the noise began. However, I have shut it off and the noise has continued. : : Your help could save a marriage! : Sounds like a loose washer somewhere in your system. It could be the house valve if it's a globe pattern and it was shut it off to make the water connection for the humidifier.However it could be in a ballcock, wall hydrant or any faucet. When water is used in the structure a lower pressure can occur which may allow a washer to displace which can 'rattle' back into place after awhile with full pressure. |
| There are none. |
