Re: where to drain washing machine?
Posted by LonnythePlumber on April 18, 2003 at 21:05:22:
In response to Re: where to drain washing machine?
: I am trying to buy a house with a septic system and washer drains directly to the outside into the yard. I have failed a septic cert. for this. there is no city sewer. I cannot tie it into the septic because it will overflow. Can I remove washing machine and all plumbing assocated with it and get it recertified? Ask the certifying authority. I am curious how you know your septic will overflow. Is your field closing off? People used to drain their washing machines into a buried 55 gallon barrel filled with rocks because certain laundry detergents would foul the bio balance in the septic. Do not do this unless you check with your jurisdiction first. LonnythePlumber
Replies to this post
There are none. |
