Re: any concern for legionnaire's bacterias for hot water return?
Posted by bob on April 16, 2003 at 22:31:19:
In response to Re: any concern for legionnaire's bacterias for hot water return?
: The bacteria that cause legionnaire's disease live in water heaters that are not kept hot enough. Is there any concern that they can breed in a hot water return line? I am about to install a hot water return line and wonder if there is anything to worry about here.
any pipe,tank or vessel that contains warm water can promote the growth of legionella bacteria, usually a stagnant condition worsens the possibility, however, setting the water heater to 135 degrees will provide a point to kill legionella but caution should be exercised - this temperature is scalding and the addtional installation of a tempering valve is recommended.
Replies to this post
There are none.
