| Posted by Bruce Keats on April 16, 2003 at 18:00:03: | |
| In response to Re: Help with new bathroom in basement. | |
Thanks for the info. If put the traps in then repore the slab then I won't have access to the trap later. My original plan was to put the shower drain with trap at the end of 2" branch line. Where do the cleanouts go? Bruce : 1. You install a trap primer valve in the water piping with its drain into the floor drain. |
| There are none. |
