| Posted by LonnythePlumber on April 14, 2003 at 19:21:21: | |
| In response to Re: main sewer clean-out | |
: Do you know that you actually have a house trap at that point? The water would not normally rise in the cleanout pipe under any conditions other than a partially plugged main line. : : I had a sewer cleaning service clean or remove the obstruction in my main sewer pipe. hj is right about the trap. Are you sure? A house trap is rare used but your jurisdiction may have them. Probably those plugs are two directional cleanouts and they face opposite of eachother so the space inbetween can be cleaned. The sewer person needs to go through both. The C.O. furtherest from your house goes toward your house and you are right the inside one goes on out to the sewer. Water should not rise in the cleanout.LonnythePlumber |
