| Posted by Gary Swart on April 10, 2003 at 13:29:51: | |
| In response to Re: Bathtub surround | |
If the wall board is still in good condition, you can cut and remove it from the top of the tub to the floor. Then shim the studs so that the tub will set flush with the remaining wall. If the existing wall is bad, I'd jsut replace it with new green board. |
| There are none. |
