| Posted by hj on April 09, 2003 at 22:36:57: | |
| In response to Re: Faucet leak | |
You could have just started a crack, if so, tightening it will make it worse. There is no rason why they could not need extra tightening, but there is also no good reason why they should. : HJ, Thanks, that clears up some things for me on info. I couldn't find anywhere. : Wouldn't a cracked faucet leak more than I described so a simple tightening may stop the leak? Would I be able to bottom out the connection if it is cracked when I try to tighten in an attempt to stop the leak? I guess I am still wondering if it isn't out of the ordinary for this one of four connections to require an extra turn or two. : Thanks again
| There are none. |
