Re: no water pressure
Posted by dave on April 09, 2003 at 20:30:12:
In response to Re: no water pressure
: i remodeled my bathroom, tore up the subfloor, replace the shower surround and fixtures. I never did this before but was pleased with my job. Two weeks after the job I have no water pressure in the tub. My water was turned off for a month, when I turned it back on it didn't seem as strong but not bad euther. Not it is a triclke. I have 2 hanndles and a shower diverter in the tub. What could cause the sudden loss of water pressure?
do you have galvinized pipes? you may have disturbed the sediment in them and its all up in your valve for the tub. same with copper if you did any soldering some solder may be in the valve. just a guess, but it has happened to me!!lol. I would pull the faucet stems out and see if your water pressure comes back up. good luck!!!!!!
Replies to this post
There are none.
