| Posted by LonnythePlumber on April 08, 2003 at 21:20:06: | |
| In response to Re: Plumbing Problem after an $18,000 work. | |
: A previous owner of our house had the following done: : 1) Tunneling under slab and replacement of cast iron waster water system with PVC. : 2) Also installed 3 two ways clean outs and repaired two water leaks. : This was for a total of $18,000. : Our problem is this. About every 3-4 months, our bathtub drain began to slow down. Then the toilet drain next to it began to shows sign that it too is slowing down and began to clog and overflow. When it does, the waste from the toilet would some how flow into the bathtub drain hole and into the tub. It is a disgusting site. We have tried liquid plumbing and none of it seems to work. : From the work done above, can any of you experts tell me exactly:
| There are none. |
