Re: Flange is up to high and toilet is will not sit flat. Back is off the ground 1/4" to 1/2"
Posted by Tim on April 08, 2003 at 10:57:29:
In response to Re: Flange is up to high and toilet is will not sit flat. Back is off the ground 1/4" to 1/2"
Do you have access to the pipe? Why did the flange end up higher than before if all you did was replace the hardwood? The flange does not have to be placed above the finished floor although this works best in many cases. If you have access then you should be able to replace the pipe and flange at the proper level. Hopefully it is PVC because that is easiest to work with.
Replies to this post
There are none. |
