Re: Quest plumbing
Posted by hj on April 07, 2003 at 23:11:49:
In response to Re: Quest plumbing
qest cannot be glued. You have to use a compression or crimped adapter and then go from that to the CPVC, (not PVC).
: I have an RV with Quest type plumbing. Can I use multi type cement to make a transition to PVC? If not is there a cement that can be used? The quest and PVC are both 1/2' diameter. Hope you can help me. Thanks John
Replies to this post
