| Posted by hj on April 06, 2003 at 23:59:35: | |
| In response to Re: tub drain replacement | |
Underneath. If it were on top the drain would be too high for the water to drain properly, for one thing. : I am replacing bath shower tub. I'm using schedule 40 bath drain from Watts. Instructions do not clearly indicate where to place the black rubber gasket at bottom drain. Should the gasket be directly on the pvc shoe elbow under the tub or above the tub on the twist n close assembly?
| There are none. |
