| Posted by Ted on April 06, 2003 at 10:08:00: | |
Water leaks from the tub while the stopper is engaged. I have a Plunger style drain and have tried to adjust the plunger to stop this slow leaking of tub water. Can anyone provide the best sequence of actions for proper adjustment, starting as if it were a new installation? Also, should this mechanism have worn out in 4.5 years? Lastly can this style drain be replaced with a pop-up style, without changing the pipes below and on the back of the tub? Thanks. |
| There are none. |
