| Posted by hj on April 04, 2003 at 21:33:06: | |
| In response to Re: Shower disconnect | |
Use a drill to remove some of the lead, then you should be able to use a screwdriver to pry the rest of it out. Otherwise just drill holes all around the circle and then wiggle the drill to remove the webs between the holes in the lead. Then lift the shower off. : Hi, : Pipes froze at my cottage last winter. I need to get the shower out to repair the broken shower pipes in the wall. Can't find anything to disconnect in the shower drain. Ideas?? : Pictures at: http://www.dconsultants.com/Cottage/shower/ : TIA, Mike McCormick
