Re: sound of water running wall
Posted by Hube on April 01, 2003 at 09:07:32:
In response to Re: sound of water running wall
: I can hear the slight sound of water running in the wall behind the fixtures on my shower/tub. There are no signs of water outside the house along the foundation or in the yard. I can even access the rear of my other tub in a connecting bathroom and see no water undernearth it.
: I can only access the back of this tub by tearing into the wall. Where can the water be draining to? I am planning on tearing into it when I get home in an hour or so. Thanks.
Tim. ; How long have you been hearing this "noise of water running" ?? You don't mention having "seen' any water, so my advice would be; If it aint broke don't fix it. if it is a water leak it would show up eventually at some point. Until it does, assume you hearing things. good luck.. Hube
Replies to this post
