Re: Washer drainage problem
Posted by Gary Swart on March 30, 2003 at 20:38:14:
In response to Re: Washer drainage problem
Three ideas. First, the drain may be partly blocked. DIY snakes are not very effective, it could have slide right by the block. Second, the pipe is too short, it should higher than the washer's tub. Third, the pipe may be too small. You didn't say what size it was, but it should be 2".
Replies to this post
