| Posted by hj on March 27, 2003 at 22:00:42: | |
| In response to Re: wall hung Kohler Toilet replacement can't be found | |
I would have to check that, since that dimension has always been a standard distance between the bolts, and I cannot imagine Kohler changing it since the carrier fittings in the wall are not adjustable in that direction. : I have two wall hung (or wall mounted) Kohler elongated porcelain toilets. They are 15 years old and each cracked where the bolt ties them into the wall. I have a metal bracket holding the bolt that goes down into the cement foundation slab. Problem is, the new Kohler toilets have a 1/2" difference in width where the nut screws onto the bolt so they can't work. I need to know where I can get a replacement toilet bowl so i don't have to cut into drywall and weld new brackets updtated width distance. HELP!
| There are none. |
