wall hung Kohler Toilet replacement can't be found
Posted by Sandra Phillips on March 27, 2003 at 18:44:27:
I have two wall hung (or wall mounted) Kohler elongated porcelain toilets. They are 15 years old and each cracked where the bolt ties them into the wall. I have a metal bracket holding the bolt that goes down into the cement foundation slab. Problem is, the new Kohler toilets have a 1/2" difference in width where the nut screws onto the bolt so they can't work. I need to know where I can get a replacement toilet bowl so i don't have to cut into drywall and weld new brackets updtated width distance. HELP!
