Re: Toilet Flange and New Tile Floor
Posted by Bronson Beisel on March 27, 2003 at 11:21:28:
In response to Re: Toilet Flange and New Tile Floor
I don't know if this helps or not, but I've been in the same situation. I've tiled four bathrooms and had the same problem you've described. I found a closet flange spacer kit at Home Depot that solved the problem. It's basically a series of rubber gaskets and a disk that fit over your existing flange and raise the height so that the flange will sit above the new finish floor height. The spacer is held in place by the closet bolts. I've used them three times, and they have worked flawlessly. Any hardware store should have something like that available. Hope this helps!
