Re: no H2O pressure
Posted by Hube on March 26, 2003 at 09:44:17:
In response to Re: no H2O pressure
: just wondering if n e one can give me a clue as to why we have no water pressure in our kitchen taps, we have it everywhere else, its just the kitchen taps that are the problem......we live in a mobile home if that is any help thnx vj
Have you cleaned out any screen that is attached to the tap? It may be clogged. Check under counter for any closed valves. Is there any water at all coming out of tap? A small trickle would indicate a blockage. If absolutely no water coming out ,check for a valve that may be shut off near the pressure pump. I assume you mean both Hot & Cold taps. Hube
Replies to this post
There are none.
