| Posted by hj on March 24, 2003 at 22:03:12: | |
| In response to Re: Pressure Reducing Valve | |
they are refilling because the water is leaking out of the tank. Replace the flappers in the tanks. : My toilets throughout the house will periodical run for a few seconds as though they are relieving pressure. I test the pressure at the outside spicket and it was 82 psi. Is that pressure too high? Should I adjust my pressure reducing valve?
| There are none. |
