| Posted by carl on March 23, 2003 at 18:08:15: | |
| In response to Re: Mansfield Toilet 130- | |
so sorry you are having trouble. most likely its not the toilet but the drain sytem that is at fault. Their maintenance, should you have to call back repeatedly, must attend to the problem by pulling the stool and "roto-rooting" the drain. Unless it is an old limed up stool it is the supporting drain at fault. You should let them know that if they dont fix the problem with repeated call backs (armed with plungers) that there is no reason to pay for these previous occurances. hope for your sake that all turns out well. out |
| There are none. |
