| Posted by Mark on March 22, 2003 at 00:23:03: | |
| In response to Re: Help! How do you dissolve/remove CPVC cement? | |
: Hello! I was cementing 1 1/2" PVC sink drain pipes with CPVC cement (I think made by Oatey) and I found out days later that the joint did not hold. : There is not enough room to cut off the section and redo it. I would like to dissolve/remove the cement from a 90 degree elbow, and reglue it. Any ideas as to how to do that? : Thanks in advance! --Robert
