| Posted by Gary Swart on March 21, 2003 at 20:36:58: | |
| In response to Re: Help! How do you dissolve/remove CPVC cement? | |
Problem is, CPVC cement doesn't just glue joints together, it welds them by causing the pipe and fitting to soften then fuse together. I fear there is no alternative to cutting the pipe and replacing the fittings. |
| There are none. |
