Re: Bathroom remodel questions...
Posted by BrianF on March 20, 2003 at 23:07:01:
In response to Re: Bathroom remodel questions...
Thanks.
Nope, there was not. It was outside wall, insulation then greenboard, then plaster, then tile. I assume you mean some sort of poly between the greenboard and insulation? I will be adding that in and using a tub surround to hopefully avoid any tile leaking assuming that's what it was.
Tub came out with several good wacks with the big hammer! Got some aggression out! Them old cast iron tubs are incredibly heavy. I split it in two and it still took two of us to lift each.
My new cast tub litterally does not even weigh close to half of that one.
Replies to this post
There are none.
