| Posted by hj on March 19, 2003 at 22:28:23: | |
| In response to Re: Old House toilet installation problem - 14 inch | |
You will not find a one piece toilet designed for a 14" rough-in. Unless you use the Toto with the telescoping fitting. And that one looks "dorky" because it has to have removable side panels to enable the connection. : We replaced a wall hung toilet tank with a modern one-piece toilet designed for a 12 inch rough-in. The modern toilet is out two inches too far from the wall. If we change to a modern toilet with a 14 inch outlet will it force to toilet tank back to the wall where we want it?
