| Posted by Kevin on March 18, 2003 at 10:22:09: | |
We have a slow drain leak that lowers our tub by about 2" during use. The drain type is a lever that drops a brass section of pipe to block the flow of water. The pipe has been adjusted up and down, and I have applied water proof grease, but we still have the slow drainage problem. The fixture only has 'Gerber' on it, no model info. What can we do to fix this? |
| There are none. |
