| Posted by hj on March 16, 2003 at 18:46:33: | |
| In response to Re: toilet installation trouble | |
You will not find a 16" toilet unless the Toto adjustable will go that far. Otherwise get a 14". Since it will be 2" further back an elongated one should clear the door like you current one, assuming it is a round front bowl. : I am remodeling a basement bathroom. It's a small room and the original toilet barely cleared the bathroom door as it swung to close. The floor drain is 16" forward of the rear wall, and the new styles seem to be made to accomodate a drain 12" from the wall, thus the new toilet not only interfers with the door, it is also 4" away from the rear wall. Do I have to move the drain or is a toilet still available to accomodate the 16" demension and still be against the rear wall? Thanks for your help. Jack.
| There are none. |
