| Posted by hj on March 16, 2003 at 18:43:29: | |
| In response to Re: Toilet high water level | |
IF you are referring to the water in the bowl, that is set by the manufacturer and if you do anything to lower the level you will probably create a toilet that does not flush properly. : The water level in the toilet is much too high. Do I need to lower the level in toilet tank or is there an adjustment I can make in the flush valve?
| There are none. |
