Re: Cutting Copper Pipe with an Abrasive Disc.
Posted by Gary Swart on March 15, 2003 at 22:31:03:
In response to Re: Cutting Copper Pipe with an Abrasive Disc.
: : It depends on what you are going to use the copper for. If it is for soldering and liquid distribution, then the cutter will leave a burr on the outside on one edge and the inside on the other. The outside one would have to be dressed down to insert the tubing into a fitting and the inside one reamed out to allow proper flow.
: : : I have about a billion cuts to do with either 3/4" M or L. Is it feasible to put a abrasive wheel on my miter saw and cut the pipe. I would think this would be much easier and quicker than the handheld cutter.
: : : Pros and cons are welcome.
: : : Thanks,
: : : Chris
: Chris;Some jobs just aren't meant to be " easier and quicker". Unless you have access to an pipe vice, the hand held cutter is the way to go. Hube
IMHO, even with a pipe vise, it's quicker and easier to use a good hand-held cutter. I don't think you'd save anytime at all with an abrasive disk, especially considering the clean-up necessary on the cut, as HJ pointed out.
Replies to this post
There are none.
