| Posted by Hube on March 15, 2003 at 16:44:02: | |
| In response to Re: Cutting Copper Pipe with an Abrasive Disc. | |
: It depends on what you are going to use the copper for. If it is for soldering and liquid distribution, then the cutter will leave a burr on the outside on one edge and the inside on the other. The outside one would have to be dressed down to insert the tubing into a fitting and the inside one reamed out to allow proper flow. : : I have about a billion cuts to do with either 3/4" M or L. Is it feasible to put a abrasive wheel on my miter saw and cut the pipe. I would think this would be much easier and quicker than the handheld cutter. : : Pros and cons are welcome. : : Thanks, Chris;Some jobs just aren't meant to be " easier and quicker". Unless you have access to an pipe vice, the hand held cutter is the way to go. Hube |
