| Posted by hj on March 15, 2003 at 15:21:04: | |
| In response to Re: Cutting Copper Pipe with an Abrasive Disc. | |
It depends on what you are going to use the copper for. If it is for soldering and liquid distribution, then the cutter will leave a burr on the outside on one edge and the inside on the other. The outside one would have to be dressed down to insert the tubing into a fitting and the inside one reamed out to allow proper flow. : I have about a billion cuts to do with either 3/4" M or L. Is it feasible to put a abrasive wheel on my miter saw and cut the pipe. I would think this would be much easier and quicker than the handheld cutter. : Pros and cons are welcome. : Thanks,
