Re: Kohler 81100 Pressure Toilet
Posted by Terry Love on March 14, 2003 at 21:31:42:
In response to Re: Kohler 81100 Pressure Toilet
Kent,
There is no way to fix them.
It's only a matter of time before the rest die too.
: I have 4 Kohler 81100 Pressure Toilets in my home. One of these systems recently had a failure at the flush valve which flooded the bathroom and bedroom where the toilet is installed. A second unit has a pressure leak at the valve, which is semi contained by the tank cover, but results in low pressure operation. Needless to say, these 2 bathrooms are out of service at this time.
: I understand that the 88100 system is out of production and has considerable risk/history of failure. Consequently, I want to replace all 4 systems at this time.
: Do you know if a modern pressure pump/tank system can be installed in the existing toilet porcelain fixture so that I don't have to replace all of the toilets and matching bidets ?
Replies to this post
There are none.
