| Posted by hj on March 14, 2003 at 21:17:51: | |
| In response to Re: Compression supply valves are dripping | |
First I would get better valves. I use them all the time and seldom have leaks. When they do leak it is usually immediately. The ring can be removed from the copper without cutting the copper off. : I replumbed my house about 15 months ago using "L" grade copper. Under the sinks I used supply valves with compression fittings (to the 1/2" copper). Since then at least half of those valves have dripped at one time or another at the 1/2" compression fitting. None of the 150 or so sweat joints have failed. : When one does leak I first try tightening - if that doesn't work I remove it and reinstall it and that usually works - at least for awhile. : Is it possible that these valves are just crap? I got them at Menards. I'm now ready to go to sweated valves. : I hate to have to cut-off any of the pipe stubs - is it possible/advisable to sweat new valves in place without removing the compression ring (that is - sweat the valve on the pipe stub that extends past the compression ring)? : Thoughts?
| There are none. |
