Re: recessed toilets
Posted by Mark on March 11, 2003 at 23:45:32:
In response to Re: recessed toilets
You definetely do not have to jackhammer the concrete!!
As Lonnytheplumber said, all you need to do is buy an InstaSet cast iron flange - it has a rubber seal that widens inside the pipe when you tighten the hex bolts!
If your pipe is ABS, you can buy an ABS flange that will fit inside the cut pipe, just like gluing a fitting.
Replies to this post
There are none.
