| Posted by Mark on March 11, 2003 at 23:29:58: | |
| In response to Re: stuck tub stopper | |
Those lever drain stops are a nightmare!! I usually remove the overflow face plate from the rod and then use needle-nose pliers and try to yank the stopper assembly out by getting a firm grip on the rod. This will work 4 times out of 5. If you still can't get it out, you'll have to replace the waste&overflow.
| There are none. |
