| Posted by LonnythePlumber on March 11, 2003 at 22:17:22: | |
| In response to Re: recessed toilets | |
: Thanks for the responses. My goal is to avoid digging up the concrete (to gain enough clearance to cut off the flange). If there is a toilet on the market that can accommodate a raised flange, that would be a simpler solution. Otherwise, I will have to go through the condo association to get approval to chop up the concrete. You do not need to break the concrete. Break off the old flange and install a new one. Lead and oakum the joint or use a compression castin iron flange. |
