| Posted by hj on March 11, 2003 at 22:13:36: | |
| In response to Re: Installing drain for pedistal sink | |
IT appears that you roughed in for an "S" trap, and unless it was from the early 20's and not relocated, the drain should have been placed in the wall. There may not be any good, or proper, way of connecting it given your situation. : Hi folks, : This is my first post. I am installing a pedistal sink in out bathroom. My problem is putting the drain together. The pedistal is not wide enough to do a normal trap. The sink drain is centered in the top of the pedistal and the waste pipe is centered in the bottom of the pedistal. Since the pedistal isn't wide enough to let the trap bypass itself in the normal fashion what is the best way to arrange the trap? : TIA,
