| Posted by hj on March 08, 2003 at 20:44:25: | |
| In response to Re: garbage disposal and level of drain | |
Yes. Water will stand in the disposer which will corrode it. In addition, when the disposer is turned on, until the water is pumped out, the disposer will vibrate because it will be out of balance. : If I get a deeper sink which lowers the level of the disposal below the level of the drain, will it push water past the trap back into the disposal. Does the disposal have to be above the level of the drain access in the wall? Thanks
| There are none. |
