| Posted by Len on March 07, 2003 at 16:16:03: | |
I have a corner shower stall. Solid base with glass door and glass walls, one-piece panels for the two back sides. I have had a cronic problem with water seeping out at the bottom rear. I've tried sealing every seam. What I think is happening is that water is getting into the metal channels that support the glass panels. Then, over time, the water is leaching out through the sealer. The drain holes on the channels may be where the water enters. They are not low enough to actually function as drains.
Thanks, |
| There are none. |
